Enable OSPF globally.
Ensure that a route policy exists.
Ensure that you configure OSPF as the boundary router.
Configure a redistribute entry to announce certain routes into the OSPF domain, including DvR host routes, static routes, direct routes, Routing Information Protocol (RIP) routes, OSPF routes, IS-IS routes or Border Gateway Protocol (BGP) routes. Optionally, use a route policy to control the redistribution of routes.
Route policies treat permit and deny rules differently for inbound and outbound traffic.
For an in-policy (RIP, BGP) or an accept policy (OSPF) using a route-map, if a particular route is not explicitly denied in the accept policy or in-policy with the route-map, then the route is implicitly allowed.
For an out-policy (RIP, BGP) or a redistribute policy (RIP, OSPF, BGP) using a route-map, even if a particular route is not explicitly allowed in the redistribution policy or out-policy with the route-map, then the route is implicitly denied.
In order to permit or deny only explicit routes, configure a policy with additional sequences, where, the last sequence permits all routes that are not explicitly permitted or denied.
Redistribute static routes from the GRT to OSPF. Create the redistribution instance, apply a route policy, enable redistribution, and apply the redistribution.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router ospf
Switch:1(config-ospf)#redistribute static
WARNING: Routes will not be injected until apply command is issued after enable command
Switch:1(config-ospf)#redistribute static route-map policy1
Switch:1(config-ospf)#redistribute static enable
Switch:1(config-ospf)#exit
Switch:1(config)#ip ospf apply redistribute static
Switch:1(config)#show ip ospf redistribute
OSPF Redistribute List - GlobalRouter
SRC-VRF SRC MET MTYPE SUBNET ENABLE RPOLICY
GlobalRouter STAT 0 type2 allow TRUE policy1
GlobalRouter DVR 0 type2 allow FALSE
Redistribute DvR host routes from the GRT to OSPF:
Switch:1>enable
Switch:1(config-ospf)#redistribute dvr
Switch:1(config-ospf)#redistribute dvr enable
Switch:1(config)#ip ospf apply redistribute dvr
GlobalRouter DVR 0 type2 allow TRUE test1
Redistribute DvR host routes to OSPF for a specific VRF vrf1:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#router vrf vrf1 Switch:1(router-vrf)#ip ospf redistribute dvr Switch:1(router-vrf)#ip ospf redistribute dvr enable Switch:1(router-vrf)#exit Switch:1(config)#ip ospf apply redistribute dvr vrf vrf1
View the DvR host routes that are distributed into OSPF:
Switch:1(config)#show ip ospf lsdb vrf vrf1
OSPF LSDB - VRF vrf1
Router Lsas in Area 0.0.0.0
LSTYPE LINKSTATEID ADV_ROUTER AGE SEQ_NBR CSUM
Router 192.0.2.1 192.0.2.1 1603 0x8000002d 0xf226
Router 203.0.113.1 203.0.113.1 1608 0x8000002a 0x4104
Network Lsas in Area 0.0.0.0
Network 14.1.1.11 192.0.2.1 1635 0x80000003 0x4909
Summary Lsas in Area 0.0.0.0
AsSummary Lsas in Area 0.0.0.0
NSSA Lsas in Area 0.0.0.0
Opaque-Loc Lsas in Area 0.0.0.0
AsExternal Lsas
LSTYPE LINKSTATEID ADV_ROUTER ETYPE METRIC ASE_FWD_ADDR AGE SEQ_NBR CSUM
AsExternal 101.1.1.3 203.0.113.1 2 1 0.0.0.0 1563 0x80000003 0xe7a7
AsExternal 101.1.1.4 203.0.113.1 2 1 0.0.0.0 1477 0x80000003 0xddb0
AsExternal 102.1.1.3 203.0.113.1 2 1 0.0.0.0 1528 0x80000003 0xdab3
AsExternal 102.1.1.4 203.0.113.1 2 1 0.0.0.0 1480 0x80000003 0xd0bc
AsExternal 103.1.1.3 203.0.113.1 2 1 0.0.0.0 1531 0x80000003 0xcdbf
The following table defines parameters for the redistribute command.
Variable |
Value |
| auto-filter-tag |
Enables route filtering to ensure tagged routes are not redistributed into OSPF. The default is disabled. |
enable |
Enables the OSPF route redistribution instance. |
metric <0–65535> |
Configures the metric to apply to redistributed routes. |
metric-type <type1|type2> |
Specifies a type 1 or a type 2 metric. For metric type 1, the cost of the external routes is equal to the sum of all internal costs and the external cost. For metric type 2, the cost of the external routes is equal to the external cost alone. |
route-map WORD<0-64> |
Configures the route policy to apply to redistributed routes. |
subnets <allow|suppress> |
Allows or suppresses external subnet route advertisements when routes are redistributed into an OSPF domain. |
vrf-src WORD<1-16> |
Specifies the optional source VRF instance. You can use this variable with the other command variables. |
<bgp | direct | isis | ospf | rip | static | dvr> |
Specifies the type of routes to redistribute (the protocol source). |
The following table defines parameters for the ip ospf apply redistribute command.
Variable |
Value |
vrf WORD<1-16> |
Specifies the VRF instance. |
Specifies the source VRF instance. You do not need to configure this parameter for redistribution within the same VRF. |
WORD<0–32> |
Specifies the type of routes to redistribute (the protocol source). Valid options are bgp, isis, direct, rip, ospf, or static. |
